Too many decimals in Textfile
Hi to all labviewers, girls as boys, lady's as gents.
I'm using the labview code in the attached JPG file,(LV vers.7.1 )
to write to a txt file. but can't control the decimals as you can see in the attched example below.
I've tried to change the data range, representation, digits of precision, data type... but no change at all. I always get this 6 decimals beind the comma! and I only needs Two digits, to print out from the text file.
Please help.!
Best regards
HFZ
Write text file example
TR1-620M
                    8933.654639 R1PO
P              221000.000000 R1PO_
P                  9310.000000 R1PO_
                   11066.433566 R2NO
P                42200.000000 R2NO_
P                15000.000000 R2NO_
                 10000.000000 R5IN
HFZ
Message 1 of 10
(4,422 Views)
Can you attach you VI?
And what is "lady's as gents" Never heard about itSmiley Very HappySmiley Very HappySmiley Very Happy
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 10
(4,418 Views)
6 is default one thats why
--Ranjeet
Message 3 of 10
(4,417 Views)
Replace your Express VI with a Write to spreadsheet and you can control those settings (dont forget to activate Append to file).
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 10
(4,407 Views)
cant you just write  it?
HFZ
Message 5 of 10
(4,328 Views)
Go to the Front Panel - right click on the element of array - Display Format...
And on the Display Format card is property Digits which determines the number of digits after comma (the default settings is 6).
Simyfren
Message 6 of 10
(4,322 Views)
The correct saying is "girls AND boys, ladies AND gents".
HFZ,
If you are going to use an Express VI instead of writing your own code, you have to accept the limitations.
Simyfren,
The display format is totally irrelevant to the format that is written to file.
Message 7 of 10
(4,316 Views)
Oh, sorry, my fault.
I read wrong what HFZ wrote..
Message 8 of 10
(4,308 Views)
My text file is being written with only whole numbers. Does anyone have any idea as to why that would be happening? I have attached a screenshot.
Any help is great!
Thank you very much,
Paige
Message 9 of 10
(4,188 Views)
You are using the "Number to Decimal String".
Notice the 999 with no decimal point.
Try "Number to Fractional String" instead.
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 10 of 10
(4,181 Views)
