How to calculate the equation from dataset using "Fitting VI's" (polynomial or nonlinear Fit) ?
I have the datasheet from a NTC (Negative Thermistor Coefficient) and I want to calculate the most approximate equation
that describes it's  behaviour. The table has temperature and resistance values. So the resistance of the NTC varies depending on the temperature it detects. I've already tried the next:
- Excel: polynomial fitting
- Maple: polynomial fitting
- LabVIEW:  Polynomial Fit.vi
I've been getting equations with a not very good approximate parameteres. I'm suspecting that this method "polynomial FIT" it's not the best method for this type of data/equation (being a nonlinear equation).
So has someone used the Nonlinear Fit.vi to approximate the behaviour of a dataset? If so, can you explain me how this VI works... I would really appreciate it.
Thanks in advance and I'll wait for your answer.
Message 1 of 25
(5,984 Views)
I have not looked at your VI.
Any fitting process needs to start with an appropriate function. To get that you need to look at the physics of your system - in this case a thremistor. A simple search will show that the resistance-temperature relationship is not at all a polynomial. Specifically, the Steinhart-Hart equation is often used.
You may be able to fit the 3 parameters of that equation to your data table using Lev-Mar or something similar.
Lynn
Message 2 of 25
(5,979 Views)
Hi JLuna,
could you convert your VI to LV2014 and attach this version too? (This would allow me and others to actully examine your VI.)
Another approach, most often very easy with good results:
Put the resistance-temperature pairs into an array of points. Then use Interpolate1DArray to get the temperature from resistance reading:
(Replace my dummy data with you real data!)
One more approach: with NTC thermistors you usually get R0 and B values from datasheet. Then apply the formulas described at Wikipedia!
Message 3 of 25
(5,959 Views)
i've just read about this equation. I didn't have notion of it's existance. Apparently it has 3 coefficients that can be
calculated. In your post you mention:
"You may be able to fil 3 parameters of that equation to your data table using Lev-Mar or something similar".
And by "3 parameters" you mean, the coefficients that are needed to be calculated. If I'm interpretating this right, there
is a Nonlinear vi, that uses the method Lev-Mar. In this VI, it has an input called "initial parameters": Is this input referring to this parameters?
**I've never used this type of VI's so I'm having lots of questions...
Thanks for your answer!!
Message 4 of 25
(5,956 Views)
Here is the 2014 version. I'll try that interpolating also... I'm a bit skeptical, because the "Interpolate 1D array"mentions to linearize the "y"values from your "x" values. But I'll give that a try also.
I just want to calculate en equation with a very low error. I dunno maybe at most, 2% error.
Thanks for your answer.
Message 5 of 25
(5,952 Views)
A higher order polynomial is a nonlinear fit. If you use more normal fit option (just delete these misquided "bisquare" and "SVD for rank defficient ..." inputs!) and things look much better!
Message 6 of 25
(5,948 Views)
Here is a 6th order polynomial fit to the two datasets leaving the optional inputs disconnected. Seems good enough.
Message 7 of 25
(5,946 Views)
But yes, if there is a suitable mathematical model with fewer paramters, you should use nonlinear fit.
Message 8 of 25
(5,942 Views)
Can you display the six order equation for those two graphics.
I generated several equations using "Polynomial Fit" and using the calculated equations I substitute a new value of my choice, for
example 23.2. And watched how this equation delivered a similar value to the graphic. So, can you display the equations please?
Message 9 of 25
(5,933 Views)
The equations are polynomials and the coefficients I found were:
32080.3
-1484.52
48.3516
-1.35193
0.0224839
-0.000180263
5.39565E-7
and for the lower set:
32080.3
-1484.52
48.3516
-1.35193
0.0224839
-0.000180263
5.39565E-7
Just put them into a DBL array and use polynomial evaluation to calculate the value for any desired x or array of x's.
Message 10 of 25
(5,931 Views)
