TortoiseSVN and LabVIEW to programmatically export modified files from one revision to another.
Can I use LabVIEW to programmatically check Modified files in a repository or folder from one version to another and export a list of paths of those files? This is when comparing one version of the repository to another.
Thank you for your help
Cheers,
~~~ GladiatorLV ~~~
(4,210 Views)
I'm pretty sure this is possible using the SVN Command Line tools (an install option of TortoiseSVN) and System Exec to call it.
(blog)
(4,206 Views)
Thank you for your reply Sam_Sharp. That's the method I am going for. Do you know the commands I should use? I have searched but haven't found any command that worked. The only one that gave me a list of modified command is ShowCompare and even that didn't take the revision number I passed. Instead a window popped up and asked me to input the revision numbers.
Cheers,
~~~ GladiatorLV ~~~
(4,198 Views)
Accepted by GladiatorLV
http://stackoverflow.com/questions/9190931/get-changed-files-from-svn-command-line-between-two-revis...
Looks like 'diff' is the right command to use.
Edit: With the --summarize flag so it doesn't try to return the actual differences within the files.
(blog)
(4,193 Views)
This is a partial solution. Thank you.
From here I will have the path of every modified filed along with the action (deleted, modified, or added) and then I can put all these paths in an array and export each into a folder on local drive.
Thanks again,
GladiatorLV
Cheers,
~~~ GladiatorLV ~~~
(4,148 Views)
