Showing results forĀ
Search instead forĀ
Did you mean:Ā
Touch Panel Shared variable binding does not work.
Is there any reason why shared variable binding is not working under Touch Panel Target?
Is there any plan for implementing or there is some trick I should know?
Andras
(4,286 Views)
Hello Andras,
which version of LabVIEW are you using?
it should work. So what for problems do you have?
Rebecca Fox
Applications Engineer
(4,269 Views)
Hi Rebecca,
I use LV8.2. (still waiting for  LV8.21 to be posted Smiley Happy ) The problem is that it is only working with reading and writing shared variables. (working ok with FIFO disabled, but ion this case controls on the touch panel should be initialized)
What I would like to do is to bind a control to a shared variable like in any other target possible.
When it runs on a touch panel (CE) target the binding is lost.
Any idea?
Andras
(4,260 Views)
Hi again,
ok know I“m understanding what you are meaning. I“m sorry in your version it will not working, also not in LV 8.2.1 but in one of the next versions. Our R&D ist still working on it.
Rebecca Fox
(4,255 Views)
Thanks Rebecca,
It is a good feedback.
Andras
(4,243 Views)
RebeccaFo wrote:
Hello Andras,
Just FYI, the KnowledgeBase article linked above has been revised and moved to a new location.  See the new KnowledgeBase 58JFBGD2: Are Shared Variables Available For LabVIEW Mobile Module (Formerly PDA Module) and Touch Panel Modules?  [article no longer available]
(3,708 Views)
