Tracking Memory Usage with .NET Processes
Hi All,
I would like to track my application's memory usage over time, so I am using the .NET process functions to do so, however I have noticed that the Process.VirtualMemorySize, Process.PrivateMemorySize, Process.PagedMemorySize, and Process.WorkingSet64 (and non 64) all will return the same value on every call. I have attached a little vi that demonstrates the issue, and a built version. I build up a large array to increase the memory usage, and can see the increase in memory usage in the task manager when I build the array, however it is not reflected in the .NET function calls. However, if I close the references and reopen them, then call them again, the values will update. Anyone know why this is? Is there another method I need to be calling to refresh the data?
(3,866 Views)
Accepted by paul.r
Calling the Process.Refresh method seems to fix the problem.
(3,845 Views)
this Process.Refresh method fixed my problem
Niki
zip code look up
(2,985 Views)
