Traditioan DAQ--Number output wanted instad of waveform
I am using traditional DAQ 7.1. I am trying to see how the numbers change while the data was aquired. However, the "AI read" VI gave out the waveform. How can I change it to numbers?
Thank you.
(3,157 Views)
I think it was a right-click choose...
Ben
(3,156 Views)
Hi Ben,
Thanks for your quick reply. I am using Labview 6.1. Right click---Select type gave me four options, Waveform, Scaled Array, Binary Array, Scaled & Binary Arrays.So there is no way I can watch the waveform and data at the same time?
Should I read the data out and then somehow make it into a waveform? Thank you
(3,151 Views)
Of course, the number array in a waveform will change the same way so the question is sort of non-sensical.
(3,149 Views)
Accepted by oly
There was a palette with waveform operators that would let you pull out the data from the WF. They work just like a an unbundle by name node. Choose the Y array and then you can look at that.
Does this have anything to do with that global Q?
If so see the link in my signature about Race Conditions.
Ben
(3,146 Views)
