Transfering data with datasocket read and FILE protocol in LabVIEW
High,
I'm trying to transfer  ASCII file with datasocket read function using FILE protocol. It works for files on the local maschine but doesn't work for network maschines.
What is a right sequence for transfering data from network?
thx
Trajan
(4,999 Views)
Hi Trajan,
it depends on your system. Do you write both sides of the transfer? You could write it with TCP/IP function. Write a client and a server. You can also use FTP commands if you have an FTP Server on your target system, or your target is linked as a disk drive, then you can copy your file.
Mike
(4,996 Views)
Hi Mike,
thanks for your quick answer. I know that is possible to do with TCP/IP client-server and FTP. It also works with HTTP nad DS read but dosn't work with FILE protocol. In the article DataSocket Tutorial is written that DataSocket supports reading binary or text files with FILE protocol but it dosen't work if the text file resides on network comupter.
regards
Trajan
(4,982 Views)
Hi trajan,
Sounds like you might have a network communication issue (firewall, etc.?). Have you tried wiring the error output of DataSocket Read to an error handler to see what comes out?
Jeff | LabVIEW Software Engineer
(4,950 Views)
Hi Jeff,
By my opinion the firewall is not a problem. Look at the attached example. The sequence  file:\\127.0.0.1\c:\ni.txt[text] doesn't work but the sequence file:c:\ni.txt[text] works. Also I attached a picture that explains generated error. If this example will work well on a local maschine it will work alsowith the remote maschine.
regards
Trajan
(4,936 Views)
Accepted by trajan
It simply comes down to permissions on the file. I made a shared directory on my local machine and it worked fine with a coworker.
For instance: file:\\ <computer name>\ToBeShared\SineData.txt[text] where I have a shared folder on the directory. It could also be the firewall.
(4,912 Views)
Hi Jeff, your explanation is useful and now program works fine with the local and network computer. Thanks a lot. I suggest, this infomation  of shearing directory to be included in the article DatSocket Overview.
regards
Trajan
(4,903 Views)
