Transparent rotating control: Is it available for LV 6.1?
(2,479 Views)
I am not sure exactly what you want, but I doubt that it exists, since LabVIEW controls cannot be rotated (but, the knobs and dials do have parts rotate). If you give more info on what you are trying to accomplish, there is probably a workable solution.
-Jim
(2,479 Views)
The knobs and dials do not rotate. They are circles with decorations that translate in a circle. This gives the appearance of rotation.
The line indicator on the control are a special rectangle that changes size and location with a routine for drawing a line from one corner of the rectangle to the other. This is interesting because the line will change orientation from one diagonal to another automatically. I have not been able to figure out how to modify the feature.
(2,479 Views)
