polymorphic VIs
Hello all,
I want to build a polymorphic VI with one string input and different outputs.
Building the VI works fine. I will find the (let's say) SubVIs within the list, and manual selection is possible. But with automated selection enabled I will only see broken wires, when wiring an indicator with different data type as at the default VI.
Question: Is it possible to build such a polymorphic VI, or is it strongly recommended to have one input for automated selection ?
Regards
Heinrich Eidloth
(2,900 Views)
Hello Heinrich,
as far as I know, Labview selects the "SubVIs" in a polymorphic VI by the inputs and not by the outputs.
So you have to select your "SubVI" manually...
Gerd Wieczorek
(2,900 Views)
> outputs.
As mentioned in the other posting, LV determines the implementation VI
based upon inputs alone. The simple indicator case makes it look like
we could look downstream, but things quickly get out of hand when the
next node is also polymorphic or is a shift register.
Another tack is to build your subVI to return multiple types. Simply
wire the datatype(s) you need and the rest dont cost much.
Greg McKaskle
(2,900 Views)
