Transpose a 1D string array
I am trying to create headers in a write to text file.  Attached is my code and what the file looks like when opened in Excel. I have my data in three columns, but the headers are not where I need them to be. LabVIEW doesn't seem to allow a transpose of a string array. Is there a way I can get the headers in a row format and not a column?
Message 1 of 21
(11,446 Views)
Add an additional "build array" after creating your 1D array of column headers. This will convert the array into a 2D array with a single row.
Chilly Charly    (aka CC)
Message 2 of 21
(11,426 Views)
Make a single string of your header strings. Put the same delimiter between them as you are using for the spreadsheet string.  You are now making an array with three elements and then appending the spreadsheet array string to that.
Lynn
Message 3 of 21
(11,424 Views)
Accepted by topic author MJ40
Something like this.
18763i723FE2FEE39EEB84
Tim
GHSP
Message 4 of 21
(11,395 Views)
Adding a build array then creates an error between the final array and the write to text file saying I am feedin a 2D array of string into a 1d array of string sink.
And in response to the second post, I am not aware that I did any delimiting with the data. I transposed it and fed it into the write to text file. The delimiting was not explicitly set. Is there a way to delimit a concatenated string?
Message 5 of 21
(11,391 Views)
If you are going to use Write to Text File, you need to feed in a string, not an array.  This code will work:
18773iB4872BB7473FAC4C
As an alternative, you could use the Write to Spreadsheet File function instead of the Write to Text File.
18775i3EEBB9879A245DF7
- tbob
Inventor of the WORM Global
Message 6 of 21
(11,366 Views)
Not true.
Message 7 of 21
(11,362 Views)
OK I didn't know that.
- tbob
Message 8 of 21
(11,357 Views)
Thanks! I was able to fix the transpose problem.
However when my data is collected I have a strange offset. I tinkered with it and got some different excel output formats but not the one I want. Any ideas?
Code1 is the Code that gives the output to excel1.
Thanks.
Message 9 of 21
(11,333 Views)
Put a probe on your header array before it goes into the last build array.  Put a probe on your data also.  See what you have there.  Put probes on each input to the last build array, see what you have there.  Finally put a probe on the final array going into the File write.
- tbob
Message 10 of 21
(11,281 Views)
