Tree not update with item deleted
I am using Tree control.
Normally, the tree gives out the tags of selected items. However, If I select one item and then delete it, the tree output doesn't change. See attached please. Thanks.
LV2019sp1, win 10
WT
Message 1 of 11
(3,208 Views)
That's a bug alright...
I can confirm this on LV20, 64 bit.
Instructions:
+ Select an item
+ Run VI
+ Notice the value in the array
+ Delete the selected item
+ Run VI
+ Notice the value is still in the array
Is this just an edit time problem? Selecting another item fixes the problem.
If this is a problem during execution, I suppose there are ways around it. We'd need a specific use case though.
Message 2 of 11
(3,179 Views)
Thanks for your comments.
I found a temporary solution by following a property setting “ Reinitial to default”.
Tree update problem_solutionTree update problem_solution
Message 3 of 11
(3,163 Views)
I think this could help me!
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(3,149 Views)
Accepted by topic author weitong
I'd probably just set the value with a property node.
Maybe even a value (signaling), if there's an event attached to it.
Message 5 of 11
(3,131 Views)
I think I actually tried this before and it didn't work right.  But it was very long ago.
Bill
CLD
(Mid-Level minion.)
Message 6 of 11
(3,118 Views)
Works for me in LV20.
Message 7 of 11
(3,111 Views)
Maybe I can revisit that software.   It was the first - and last - time I used a tree control and I was disappointed with it, to tell the truth.
Bill
CLD
(Mid-Level minion.)
Message 8 of 11
(3,106 Views)
It's a wild beast to tame.
A tree and a subpanel showing the selected item, and item specific right click menus, can replace very complex alternatives. For some applications, there's really no substitute.
The API isn't exactly intuitive, but I'd almost always wrap things in a class anyway.
Especially custom drag and drop functionality is not as easy as it should be. The moment you catch one drag and drop event, you need to handle all drag and drop events. But this is the same for listboxes.
Message 9 of 11
(3,097 Views)
I think I was most disappointed that the names weren't namespaced.  If the same name occurred ANYWHERE in the tree it gives it a new tag name, which complicated the code somewhat.  It wasn't as elegant as I had hoped it would be.  I was hoping to use it to duplicate a CLI command tree.
Bill
CLD
(Mid-Level minion.)
Message 10 of 11
(3,085 Views)
