what can create channel
current sensor -- output: voltage --> ni(currentChannel? or voltageChannel?) -->????
(1,039 Views)
You forgot to add a few words explaining what hardware/software you are using or want to use. Not all people love riddles.
What I understand is the following: you have a sensor that measures electrical current; the sensor output is in voltage. Right? Then your measurement channel must be voltage. Then, rescale to current according to the sensor calibration data.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(1,016 Views)
