I have a treeview control that I can perform drag and drop while in edit mode but once I build the executable I can't drag and drop any longer. Are there some settings that I have to change?
I am not using an Active X Control but instead the TreeView control within LabView 8.
I will try to program the treeview control using event structures and try to mimic the drag and drop behavior. Hopefully the necessery fixes will be released sooner than later!
