Treeview control will not drag and drop when project is built.
I have a treeview control that I can perform drag and drop while in edit mode but once I build the executable I can't drag and drop any longer. Are there some settings that I have to change?
I am not using an Active X Control but instead the TreeView control within LabView 8.
A response would be greatly appreciated.
(2,578 Views)
This is a known bug, see further down in this discussion:
http://forums.lavausergroup.org/index.php?showtopic=2271
(2,573 Views)
Thank you for your quick response.
I will try to program the treeview control using event structures and try to mimic the drag and drop behavior.
Hopefully the necessery fixes will be released sooner than later!
Thanks!
(2,550 Views)
