Treeview: mark multiple objects possible?
I'm using a treeview control (from LabVIEW lib), is it possible to mark multiple object like in Windows explorer?
I mean hold left mous button, move mouse over and select a bunch of objects.
Thanks for tipps and answers!
(2,942 Views)
I think this should give you some hints:
Norbert
Norbert
Expert: Geometry
(2,941 Views)
Hi Norbert,
yes I found this already, this will work! (Multiple selction by pressing Schift or Ctrl key works, too)
I hoped is would be possible to select the items only by using the mouse, maybe someone has an idea.
If not I do it like you said, thank you!
(2,939 Views)
