Triangular wave generation on FPGA target
I am using PCI 7831R  DAQ card. I am trying to generate a triangular waveform as an output from this card using labview 2016.
Kindly suggest a solution as the triangular wave form option is not available on the FPGA target VI. How can I make the triangular wave form.
Waiting for response
Ekansh Garg
CSIO
Message 1 of 10
(4,113 Views)
Hi Ekansh,
A triangular waveform consists of ramps between min and max: you just need to interpolate between your min/max values over time (or iterations of your FPGA loop).
What have you tried and where are you stuck? Mind to attach your code?
Message 2 of 10
(4,097 Views)
Basically i want a sawtooth wave signal from my FPGA analog output pin, for which time and amplitude can be controlled in real time from lab view. Here is my code and snippet.
Please tell what am I missing out.
Waiting for you response.
Ekansh,
CSIO
Message 3 of 10
(4,055 Views)
Hi ekansh,
you miss to recognize that coercion dot! Such coercion dots have a purpose: read the LabVIEW help...
Suggestions:
  • Stay away from express VIs and their DDT wires!
  • Create the sawtooth in the FPGA.
Message 4 of 10
(4,049 Views)
Hi
I am facing the same challenge with the sawtooth generation on the fpga.
The above resources are in accessible when I tried to access them.
Here is the snippet of what I attempted to do.
Message 5 of 10
(4,052 Views)
Hi again,
Is there a way to directly control and send sawtooth signal in real time to the FPGA I/O PIN from my VI (which is on host PC) in order to avoid repetitive code compilation on the FPGA target, as currently I am in development phase of the code . Is there a way to do so?
Best regards
Ekansh
CSIO
Message 6 of 10
(4,031 Views)
Please suggest a solution of how can I generete a sawtooth signal on the FPGA I/O PIN directly from the host VI in the real time, to avoid repetitive compilation on the fpga target.
Message 7 of 10
(4,024 Views)
Hi Ekansh,
please don't hijack (very) old thread when you already started your own discussion thread!
Keep related posts in just one thread!
Why do you need to compile "repetitive"?
As I suggested before: create the sawtooth signal inside the FPGA VI using simple math functions!
The FPGA only needs 3 inputs: min + max of the sawtooth signal and number of clock cycles for a full period.
I recommend to use FXP datatype: use the same FXP definition as is used by the AO pin…
I'm used to cRIO AO modules which use FXP datatype. As your device uses I16 you need to scale/round from FXP to I16…
Message 8 of 10
(4,018 Views)
Hi there again, I managed to generate triangular wave form, Thank you.
Now I am using a time delay inside a loop which is generating the wave form, but a little change in the time delay results in abrupt change in signal frequency. I am guessing this is because time delay function cannot take decimal values so it reads them as 0.
So,
1)Can Time delay read values in decimals.
2) Is there a delay option fro values in micro second.
I have attached my code below
Warm Regards
Ekansh
CSIO
Message 9 of 10
(3,960 Views)
Accepted by EKANSH_CSIO
Hi Ekansh,
Did you do any of those basic LabVIEW training resources to actually learn LabVIEW and DATAFLOW?
Why are there so many local variables?
Why are there sequence frames when DATAFLOW should be used?
Why are there wrong datatypes, like orange wires where blue wires are expected?
See this:
No locals, no frames, just dataflow! (This will still not work as expected due to your other problems.)
  1. The Wait(ms) function can only wait in integer multiples of ms - as can be read in the LabVIEW help!
  2. Why do you want to wait in µs? This will not work reliable - not in Windows and not in NILinuxRT…
Does your VI run in the RT host or in the FPGA target?
Why do you create the waveform in the RT host, when you should do that (much better/more accurate!) in the FPGA target?
Message 10 of 10
(3,956 Views)
