Tried to download evaluation software, not working
After approximately a half an hour of downloading of NI LabVIEW Evaluation Software it faild to unzip, and I couldn't get it running.
(2,709 Views)
I just tried the same thing and it worked fine on my machine. Did you make sure you downloaded the correct version? I'm running Win 2000 and downloaded that version. You may also want to try reinstalling your zip utility. Maybe that's the problem.
J.R. Allen
(2,709 Views)
I tried to download the LabView Evoluation Software again today, the same result. It gives me the message, when you try to unzip:
ZIP damaged file
C:\TEMP\m6.cab. Bad CRC7291b8a1(Should be c9f55f4d)
Possible cause: file transfer error
Please explain this prompt.
We have been running Windows NT here, and I downloaded the right version of the NI software.
(2,709 Views)
