05-23-2012 02:15 AM
Hi all,![]()
I am new to this WT500 and WT3000 power analyzers. I hope some one worked in WT500 or WT3000 trigger measuremen can help me immediately.
My application goes like this:
Does this operation possible with WT500 or WT3000?
Ajay.
Solved! Go to Solution.
07-22-2012 11:43 PM
Finally I tested myselft spending 8hrs of my time to find out the Trigger based measuremnt in Yokogawa. Following are the steps I used to test it.
07-22-2012 11:50 PM
Hi Ajay,
So you found out it is possible using WT500/WT3000.Anyway congrats.
08-16-2012 08:43 AM
Hi Ajay,
In the future if you ever need help with Yokogawa products, you can call their customer support or visit their forums. It might save you some time/frustration from having to figure everything out by yourself.
http://tmi.yokogawa.com/us/forum/
