Trigger button click programatically after a specified time
Why did you take the capture out of the producer loop. That is NOT what I said to do. You decided to take an additional step that broke the basic capture.
Message 21 of 33
(3,064 Views)
How should I pass the image to the snap image screen?
Message 22 of 33
(3,061 Views)
We are almost done unless you don't make crazy things like what you just did.
-Why you kept grab outside loop? (keep it inside only)
-Please disconnect the Obtain Queue name input(Please i have been telling the same from beginning why you connected Session out to this terminal??) and give proper name.
-The enqueing is proper and you don't need any wire to be connected from top loop and bottom loop (as already Dennis and myself told).
-Snap image should be connected to Dequeue element output.
-In producer loop, for case structure case selector use output elapsed time and keep it to 500ms.
-For your question, that is the beauty of queues. In enqueue you will send image and receive image at dequeue without any wires.
uday
Message 23 of 33
(3,028 Views)
I already made the changes you told me to, but I still can't get an image.
Please help me out.
Thanks in advance!
Message 24 of 33
(3,021 Views)
Accepted by nando1988
Just two things. The only way to thank in forum is by giving kudoes and making the proper solution as marked solution.
-I didn't mention Wait(ms). i told you to keep elapsed time where is that??connect it to case selector input as suggested.
-Reduce wait(ms) time so that producer loop runs fast.
-You know what it is working for me here with those changes so hopefully V1.8 should be final 😛
uday
Message 25 of 33
(3,014 Views)
You've got a false constant wired to the case statement so the image is not being written to the queue. Are you now getting a continuous stream?
Message 26 of 33
(3,010 Views)
I reduced the wait time to 1, but I don't understand what do I have to connect to the case selector and where exactly is that.
Message 27 of 33
(3,004 Views)
Right click in Block diagram, go to timing group. get Elapsed time there. You have used it in your version1.2.
uday
Message 28 of 33
(2,999 Views)
To which case selector should I connect the elapsed time to, to the producer or consumer loop case?
Message 29 of 33
(2,993 Views)
Producer please 😛
uday
Message 30 of 33
(2,990 Views)
