Trigger case structure using OPC variable
I am using OPC to communicate Labview with a Siemens PLC. One memory location from the PLC will work as a flag that triggers a case structure in Labview.
However I only want to trigger that case structure once.
So far the vi seems to work but the case structure just keeps on executing because I do not know a way to use the flag of the PLC as a edge trigger.
Could anyone help me please?
(4,415 Views)
OpenG toolkit actually has a Boolean Trigger which may be useful. Here is a simple implementation with shift registers. I'll let you fine tune it if you only want it on the rising edge 🙂
(4,374 Views)
If you are feeling stuck I would search more specifically for LabVIEW FPGA rising edge detection. It is something that is done pretty often in FPGA and there are some really clever implementations. A lot of the examples will use feedback nodes which will make it really easy to put in a subVI as well.
(4,356 Views)
Thanks a lot man! I didn't know about openg libraries, the boolean trigger over there saved me.
(4,331 Views)
