01-24-2006 10:11 AM
01-24-2006 11:11 AM
01-24-2006 11:20 AM
01-24-2006 02:32 PM
Hello again Adam.
I have looked though your vi, and can follow most of what is going on.
I have a quick question, if you don't mind.
What is the function of the trigger index?
Regards
Tom
01-25-2006 02:31 AM
01-25-2006 07:02 AM
01-25-2006 07:09 AM
Tom,
All I sent you was a basic working vi that shows the principles behind the triggering you need (and pre post display)
have you set up all of your channels and wired them in etc? What's not actually being plotted and where isn't it?
You may need to change the code to actually display and store the plotted data on your graphs/charts.
Maybe you would like to post what you have so far (code wise) and what you are seeing. I'll see if I can have another look at it for you?
Thanx
AdamB
01-25-2006 07:15 AM
Tom,
Another quick thing.
You did actually put a chart indicator on the front panel didn't you? And connected it up directly to the output of the Read channels task?
(the graph I showed you simply displays the pre and post data and then holds that until another trigger is read)
AdamB
01-25-2006 07:58 AM
01-25-2006 09:02 AM
