Trim Whitespace.vi is not re-entrant. Why?
The "Trim Whitespace.vi" is a very useful utility and gets sprinkled all over a project.  It can be called from various simultaneous parts of a project as well as from independent top level VIs.  As such I would think that it should be re-entrant?
I have been seeing choppy response from two different simultaneous top level VIs and one of the shared sub-VIs is "trim whitespace".
This seems to just be a configuration oversight?  This utility seems to have been written long ago (~ 2002) and has been blocking execution ever since.  I have lots of CPU cores and forcing single threading seems to be unnecessary here.
LabVIEW ChampionLabVIEW Channel Wires
Message 1 of 95
(5,568 Views)
Is it faster/smoother if you make it re-entrant? At least in 2017 there's no reason I can see that you couldn't do that, although I guess that isn't the point of the question...
GCentral
Message 2 of 95
(5,551 Views)
Hi sth,
strings are unlimited in size: using TrimWhitespace in parallel might result in huge memory consumption...
The compiler will also optimize this function to remove the different case structures inside for the op mode...
Message 3 of 95
(5,548 Views)
I remember reading either here or on lavag.org that the trim whitespace is used all over the place that making it re-entrant would cause LabVIEW to run out of memory, this was from AQ. If you need to use it in a tight loop then roll your own or use the primitives. The snapshot is from the Error Cluster From Error Code.vi, these are NI's comments.
mcduff
Message 4 of 95
(5,524 Views)
I've never really understood what the difference is that makes Match Pattern improve performance over a regex match.  I suspect there is a caveat or two that we are missing in the help file.
Frankly, Trim Whitespace.vi could be improved with some code I serendipitous wrote yesterday for a similar problem.
Message 5 of 95
(5,520 Views)
So the point is that all of the lowest 33 ascii character codes are trimmed? With 33 being the first non-whitespace character?
Is that the same behaviour as the trim whitespace VI?
GCentral
Message 6 of 95
(5,517 Views)
NO! Trim Whitespace.vi only searches ^[\t\n\r\s] and [\t\n\r\s]$  Trim String.vi attached throws out everything below "!" Other than that caveat they are very similar
Message 7 of 95
(5,513 Views)
@Jeff
Works nicely! I will wait before I test it to see if Altenbach posts a faster solution. Smiley Very Happy
mcduff
Message 8 of 95
(5,511 Views)
Nah, I am more of a "numbers" kind of guy. 😄
Message 9 of 95
(5,497 Views)
A "complex" guy 😄
Message 10 of 95
(5,481 Views)
