Trim Whitespace.vi - remove unused polymorphic VI instances
Hello All
From some time while building the exe file I have started to receive the error:
Error 1073 occurred at E:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\Utility\error.llb\Trim Whitespace.vi
Possible reason(s):
Application Builder: Unable to disconnect type definitions and remove unused polymorphic VI instances for this application. Deselect this option on the Application Settings tab and build the application again.
It did not happen before. Of course I can leave all polymorphic vis in my application, but why I started to get this error? It never happened before. Especially that the Trim Whitespace.vi is not a polymirfic vi.
Any ideas?
thanks in advance.
Pawel
(3,186 Views)
Hello Pawel
Does your vi have a blockdiagram???
Try to take a look at this KB...
http://digital.ni.com/public.nsf/websearch/6A1A31BD5EBE484886256E85005CE553?OpenDocument
Regards
Mohadjer
(3,186 Views)
Hi Mohadjer
Demn.... I remember now. I started to get this error when I saved my vi (for other purposes) with removed diagrams. Probably it removed it also from the vi.lib vis. Wow.... Now I am having problems, how many vis I have destroyed when this happened.
Anyways, thanks a lot for this. At least I know what I have done :).
regards
Pawel
(3,186 Views)
