Trouble creating tasks after upgrade to 8.5.1, says RT and Host have different NI-DAQ
Hello all,
After upgrading to 8.5.1 (both Windows host and RT), I went to MAX to create some tasks for the DAQ in the RT chassis. Upon creating the tasks and trying to save them, it thows Error -88716, which means the Host and RT have different versions of NI-DAQ.
The Host has NI-DAQmx 8.7.1f2.  The RT has NI-DAQmx 8.7.1.
Any ideas? I've tried reloading. What's the "f2?".
Richard
(3,359 Views)
Hello Richard,
I've got a similar issue. See here http://forums.ni.com/ni/board/message?board.id=170&message.id=316662 for my post.
No solution found yet.
Regards
Ludos
(3,327 Views)
Ludos,
The solution for my problem was to download and install NI-DAQmx 8.7.1f3. The f3 means "fix 3". This fixed the issue of RT and Host not seeing the same version of NI-DAQmx, and I'm now able to create tasks and run the DAQ. This is a known issue at NI with the driver that ships with 8.5.1 (which is NI-DAQmx 8.7.1f2).
-Richard
Richard
(3,312 Views)
Thanks a lot.
Works great after installing 8.7.1f3 on both host and target... after downloading this BIG update...
Regards
Ludos
(3,281 Views)
