Has anyone had trouble opening a VI by double-clicking on it in Explorer on a Windows XP machine? On our systems, if you double-click on a VI, the titlebar of the VI will appear, but the front panel won't show up. After about 30 seconds, a window pops up with the message "Windows cannot find XXX. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.", where XXX is the VI that you just double-clicked on. I've enclosed a screenshot of this problem.
If you launch LabVIEW first, then double-click on the VI, it opens fine.
Any ideas on what is going on? It's not a major issue, but it is annoying. Also, I suspect that it is related to another problem we are having, in which the program hangs on a dynamic call, after which you cannot open any VI by double-clicking on it in Explorer. In both cases, it seems to be a problem with LabVIEW and Windows XP.
Tom
