Trouble reading from serial instrument and DAq simultaneously.
Greetings,
I am having some trouble getting my VI to read from my DAq and a serial instrument at the same time.  If I run the subVI's simultaneously (i.e. subANG is running in one window and subVEL is running in a second window) both return the proper values and behave as I would expect.  However, if I call the subVI's into a parent VI and try to run them both in the same loop structure subANG gets stuck and will not resond with a change in signal.
I have also tried to use a stacked or flat sequence to separate out the execution of subVEL and subANG, but I still get the no response from subANG.
The most confusing thing is that if I run Parent.VI in one window and then create a copy of subANG (call it '....-copy' or whatever) and run it in a second window, Parent.VI behaves properly and will refresh the readings as they appear in '...-copy'.
I have attached 3 files.
(1) subANG.VI     -This reads an RS232 signal from an inclinometer.  The signal is refreshed every 10ms or so.
(2) subVEL.VI      -This reads raw voltage from one channel on the DAq, calculates the mean then converts that into a pressure differential and finally a velocity based on the pressure and temperature inputs.
(3) ParentVI.VI     -This simply calls and displays the subVI's
My guess is that it is a buffer issue, but I am stumped.  Does anybody out there in Labview land know why this might be happening?  All suggestions welcom.
(2,850 Views)
Forgot the attachments.  Sorry!
(2,845 Views)
Oops again.  Uploaded the wrong files.  Please use these for your reference.
(2,844 Views)
I am noticing it is not an NI DAQ card.  How are you communicating with the DAQ? If it is using a serial port, that could be your problem.
I also highly recommend using the VISA drivers for serial communications instead of the serial.llb VIs.
(2,836 Views)
Accepted by BrownBrown
It's not a serial instrument.  It is a UEI PowerDAq with their typical A/D and cable.
I did find away to make it work by placing subANG and subVEL into different while loops side by side in ParentVI.
(2,816 Views)
