Trouble recognizing connected BK8500 on LabVIEW
I currently have a BK8500 connected to my computer through a USB to TTL interface and I have downloaded the BK85XX drivers from LabVIEW. Sadly when I open SystemDesigner and attempt to view live hardware it does not show up. Also when I try to identify an instrument on my serial ports it says that an instrument is "not found".
I am new to this software so I apologize if the question is confusing or the solution is obvious.
Thanks.
Message 1 of 10
(4,286 Views)
What is SystemDesigner ?
Message 2 of 10
(4,264 Views)
For LabVIEW NXG 4.0.0 it is a mode to view connected hardware in a block diagram format as far as I know. Seems a bit similar to Simulink.
Message 3 of 10
(4,260 Views)
The BK8500 won't show. What shows up is a COM port if your USB-TTL adapter is designed as one.
Message 4 of 10
(4,252 Views)
I'm using the usb to TTL interface from BK Precision and its connected to COM3 of my computer. It is visible on my device manager but on LabVIEW I cannot even view that communication port, only COM1 is available to edit its baud rate and such.
Message 5 of 10
(4,248 Views)
Post screenshot of your Device Manager.
Message 6 of 10
(4,245 Views)
Device Manager with COM3 connectionDevice Manager with COM3 connectionLabVIEW only COM1 availableLabVIEW only COM1 available
Message 7 of 10
(4,164 Views)
Also here is a screenshot of the driver I've installed
Message 8 of 10
(4,161 Views)
The only thing I can think of is that another program is using COM3 .
Message 9 of 10
(4,146 Views)
Hmm. I gave up. Switching to a bk8601 which has an actual usb port and it all works fine.
Message 10 of 10
(4,082 Views)
