Trouble running a VI asynchronously when called from Python via COM/ActiveX interface
For literally decades, on Windows platforms, I've been controlling LabVIEW vi's with Perl scripts using the COM/ActiveX interface. Now I am trying to control LabVIEW vi's from Python scripts, but I am having trouble running vi's asynchronously.
Below is a simple script which opens a vi, sets a control value, and reads a couple of indicators as well, and runs a simple vi, which has a while loop controlled with a boolean Stop button.
import sys
import win32com.client
lvRef = win32com.client.Dispatch("LabVIEW.Application")
viName = 'C:\\perforce\\PythonDev\\software\\LabVIEW\\pythonTest.vi'
viRef = lvRef.GetVIReference(viName)
viRef.SetControlValue('U16 Control', sys.argv[1])
value = viRef.GetControlValue('U32 Indicator')
print(value)
array = viRef.GetControlValue('U16 Array Indicator')
print(array)
viRef.Run
print("VI done")
By default, the vi will run synchronously. That is, the Python call, viRef.Run, will block until the vi execution is complete, via the boolean control to the while loop. This is all working as expected.
But I want to run the vi asynchronously. That is, I don't want the Python script to block after calling viRef.Run. I want the vi to keep running, and let the Python script continue execution.
The Run method actually takes an optional parameter, "async", which when set to TRUE, the vi should run asynchronously, and the Python script should continue executing, but it sill blocks. In fact, if I pass any parameter to Run, such as viRef.Run(0) or viRef.Run(1), the vi will still run synchronously, but now when I stop the vi, I get the following error:
C:\perforce\PythonDev\software\Python>LabviewTest.py 55
16
(0, 1, 2, 3)
Traceback (most recent call last):
File "C:\perforce\PythonDev\software\Python\LabviewTest.py", line 11, in <module>
viRef.Run(0)
TypeError: 'NoneType' object is not callable
I'm a Python newbie and don't really understand this error message in this context ...
For what it's worth, I had no problem with this when using Perl. I could pass a 1 to the Run method and it would run asynchronously, that is, the Perl script would continue executing, as expected.
Any ideas on what the issue is? I'm running LabVIEW 2017, 32 bit version. I've tried both 32 bit and 64 bit versions of Python 3.9.
In this NI forum, I did find a simple example of using Python to control a vi, (https://forums.ni.com/t5/Example-Code/Controlling-a-VI-using-Python-using-LabVIEW/ta-p/3536468?profi...) where the Call() method was used to run the vi, but that wouldn't run asynchronously either. (I did find a kludge using Popen to spawn another "shell-less" Python instance which runs the vi, but I would much rather figure out how to use the Run method)
Greg Mathis
(3,071 Views)
What if, instead of running the target VI directly, you just ran a "launcher" VI that does nothing but load a different VI by reference, start it running asynchronously inside of LabVIEW, and then exits?
https://www.ni.com/docs/en-US/bundle/labview/page/asynchronously-calling-vis.html
(3,053 Views)
That is a good idea. I quickly whipped up a "launcher" VI just like you suggested and it does provide a simple solution, much better than spawning another Python instance to launch the VI. I would still like to figure out why passing the "async" parameter to the vi.Run method doesn't work with Python, but does work with Perl.  But in the meantime, I'm going with your suggestion.
Thanks!
Greg
(3,044 Views)
@gpmathis, did you ever get a solution to this problem, other than creating a launcher vi? I've come across the same problem as you described using LV 2023 Q3 with Python 3.x
(2,085 Views)
I know this post is years old but I thought I'd reply for the next person who comes across it.  I was able to get a vi to run asynchronously from Python as follows:
# Create VI reference
vi = labview.GetVIReference(vi_path)
# Run VI
vi._FlagAsMethod("Run")  # Flag "Run" as Method
vi.Run(1)
Without _FlagAsMethod you can't pass parameters to the Run method.  This allows you to call Run with the parameter async = 1.  I can't say that I really understand what's happening, perhaps someone else can explain it.  I first learned about the _FlagAsMethod function in the following example, and a colleague suggested that I try it in this case.
Controlling a VI using Python using LabVIEW
I hope this is useful to someone.
(1,016 Views)
This is very useful. I had moved on from this effort a while ago, but unbeknownst to me, some other co-workers kept at it, and this _FlagAsMethod is exactly how they fixed it. Thanks for contributing!
(874 Views)
