Trouble when Labview call CVI DLL in after compiled to EXE
I m developing a program by LabVIEW, and have to call a DLL, which developed by using CVI.
The UI of the DLL consist of a table and a listbox.
The DLL run smoothly but when I compiled the project to EXE, when the program call the DLL, the DLL won't show properly.
The DLL UI only show the table, and the listbox has "disappeared".
Any common known-problem caused it ? Please advise. Thanks a lot.
(2,431 Views)
Hi Engwei,
I'm not familiar with any such issue. Would it be possible for you to post the corresponding CVI and LabVIEW codes and the built DLL and executable? I would like to investigate this issue further. Also, what version of CVI and LabVIEW are you using?
Thanks!
Joshua de la Llana
NI Applications Engineer
(2,385 Views)
