motor rotation animation (clockwise, anti-clockwise)
hi all, can anybody tell me how the shaft of a motor can be animated to rotate clock-wise and anti-clockwise direction. precisely , from this website below, how can i make similar
http://members.lycos.co.uk/sgctek/motor.html
plz guide
(6,297 Views)
Hi freemason,
you can use different images which you draw into a picture control. You can load the images from a gif and use an array to store them. Draw one image after the other into the picture control. You can do it inside a loop.
Hope it helps.
Mike
(6,283 Views)
Hey freemason,
Mike has a good suggestion. It sounds like you may also be interested in setting up a picture ring control. Check out this Knowledgebase for some more information on how to set up a picture ring control.
Essentially, the examples that can be found on the website you linked are just a series of 7 pictures that represent the entire revolution of the shaft. Each picture is associated with an integer. There is then a loop that controls the speed at which the program goes through the 7 integers and thus the 7 pictures. If you haven't already, take a look at the block diagram and you might get a little more insight into how those examples work.
Hope this helps.
-Ben
Applications Engineering
Hope this helps.
-Ben
WaterlooLabs
(6,244 Views)
Thank you both
(6,233 Views)
