driver installation yields blocks with a question mark, however when I open the
I am trying to install the Agelent E3645A driver.
Michael C. Nedrow
(3,143 Views)
Looks like part of your message subject was cutoff.  How about some more details?  What version of LV are you using?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,142 Views)
I have just installed 8.6.1
It feels like an embarrasing question..............
seems like I am missing a step in the driver download.  I downloaded the driver, extracted all files to the folder under instlib.  I do not get the icons when I look at that folder in LabVIEW, however things look ok from the lib manager.
Michael C. Nedrow
(3,136 Views)
OK, I had a similar problem once (maybe).
Did you try rebooting your PC and re-installing the drivers?  Logging out would probably work too, but I don't know for sure.
-Matt Bradley
(3,127 Views)
I will try it........
Michael C. Nedrow
(3,123 Views)
No Luck;
when I try to use the icons all I get is a question mark.   I have experienced this with other drivers, never Agilent
Michael C. Nedrow
(3,119 Views)
Next thing to check is if your drivers were installed in the right place.  Can you figure out where they were installed?
-Matt
-Matt Bradley
(3,094 Views)
