Trouble with Writing to spreadsheet file
Hi GerdW, yes, I'm reading the string from myRIO. But, I've also tried reading using the basic random number, the data is not getting in the spreadsheet as well.
Message 11 of 16
(1,196 Views)
Hi Jia,
again: the myRIO does NOT have access to your PCs harddrive!
You need to store the file on the myRIO harddisc (or flash drive) and copy it over to your PC! And you need to use a file path which is valid on your myRIO!
Message 12 of 16
(1,192 Views)
I have same problem, but when I change the path to flash drive like you said,it still doesn't work,
can you explain it more detail about the solution please.
thank you
Message 13 of 16
(935 Views)
Hi Awan,
Which path do you (try to) use then?
Does your RIO RT target have any D:\ drive?
Message 14 of 16
(930 Views)
I use G:\ , it is in my flash drive. outside my PC harddrive.
Message 15 of 16
(924 Views)
Hi Awan,
as has been said several times before: a RT (RIO) target does NOT have access to any drive connected with your host computer!
You need to choose a file path available on your RT target - most probably something starting with "c:\"!
Message 16 of 16
(913 Views)
