True and False - Possible Combinations
Hello
I have three booleans in my code and the combination of their values (true or false) control another part of the code. Since there are three booleans and they can be true or false, I have 8 possible combinations (2^3). What should I do to, considering the values of the three booleans, have a numeric indicator that show which combination I have? The range of the numeric indicator will be 1 to 8.
Thanks in advance
Daniel
(21,520 Views)
Accepted by dan07
Create an array and then use the Boolean Array to Number.
(21,513 Views)
Perfect solution! Sorry for the stupid question! Smiley Happy
Thanks!
Message Edited by dan07 on 08-04-2009 06:55 PM
(21,508 Views)
I have one more question. I would like to convert these 8 combinations to 0 and 1 combinations. Considering 0 as false and 1 as true, we will have 8 combinations like this:
000
111
110
011
010
100
001
101
What code should I use to generate, for example, a array with these sequences? One sequence as each element of a string array, for example.
Thanks.
(21,499 Views)
Like this?
Message Edited by altenbach on 08-04-2009 05:29 PM
(21,493 Views)
Exactly!
Thanks!
(21,487 Views)
