Try to implement my transfer function
I have seen a lot of ex. about transfer function implementation, but i need to implement my TF without using a Control Loop, just a while loop with a "transfer function" function from CDeSimulation.
The point is very simple: just filter a signal with a low pass filter using my own transfer function and take the output signal, in the domain time..
I try to realized a project (if you want to see in the attachement file) but it isn't working, even if i put very simple TF and basic signal. So i wonder if anyone had the same problem or just can see where the problem could be..
Thank You.
Nigeltorque
(2,428 Views)
duplicate post
Please stick to your original post
(2,417 Views)
