Trying to find a function/sub VI/Somehting that will calculate an average minimum (sort of?)
Hey guys,
I've got some data (noise) and I want to find what I would call an average minimum value for the noise as opposed to the single absolute minimum.  I'm wondering if you guys know of anything in LabVIEW I could use to do this.  I've attached a picture to explain what I mean.
Jeremy
(2,665 Views)
If you're talking about averaging all the minimum points, I believe you should be able to do this by calculating the first and second derivatives of each point.
There is probably a VI for a point by point derivative or for an array derivative in the analysis palettes.
If this isn't what you want, you should explain what calculation is needed to obtain this.
___________________
Try to take over the world!
(2,660 Views)
There are many ways to do this. Perhaps you can simply plot histogram of the y-values and select the point where you have largest change.
Example histogram:
************************************* (select this y-value)
Tomi Maila
(2,649 Views)
