Trying to trace inputs to physical modules
Hello all,
I recently was assigned to a project that had some LabVIEW code already set up, along with the physical system the code is meant to be controlling.  The system uses 3 NI cards, NI 9221, NI 9474, and NI 9422 :
https://www.ni.com/en-us/shop/model/ni-9221.html
https://www.ni.com/en-us/shop/model/ni-9474.html
https://www.ni.com/en-us/shop/model/ni-9422.html
My problem is that looking at the LabVIEW code itself, all of the I/O names are variations on cDAQ2ModX/portY/lineZ.  It's been years since I've used LabVIEW, and I'm having trouble findings a way that I can tell to determine which cards are sending and recieving which signals from which channels.  Is there a way to dig into the code to determine this that I'm missing or have forgotten?
(2,264 Views)
Check MAX. (Measurement and Automation Explorer)
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,233 Views)
