Tunnel mode (concatenate problems)
Hi
I have a programme i writting at the moment. I am using a for loop for taking measurements. Measurement are taken at specfiic intervals previsoly determined. At each interval the for loop runs takes a set of measurements and send them to 1D arrays on the front panel. I am using the tunnel mode feature of labview 2013 to concatenate the array.
The problem i am having is loop runs takes all the measurments concatenates them and once the loop has finished you can then see them on the front panel. If i want to see the measurements going into the array as they are taken how do i do this.
attached is a picture of the for loop
(2,974 Views)
You can concatenate data in your loop by using "build array" function and displaying the resulting array in the graph.
Otherwise you can use a chart instead of a graph.
(2,964 Views)
