Turn off icon numbers in new sub-VIs
New in 2009 per the help file
Message 11 of 13
(1,492 Views)
Hi!
After installing last version (LV 2012, SP1) I've got the same problem.
I've found this post, changed the option "Use numbers in icons of new VIs (1 through 9)", exit and re-run LabView. But numbers in new VIs are still there when I'm overriding a method in the ancestor class!
Help if possible, please.
Ljubo.
Message 12 of 13
(1,451 Views)
 I'm in 2013 and adding the "UseNumbersForNewVIIcons=FALSE" to my LV .ini file just now worked for me. Have you given that a try, Ljubo?
Cheers
Message 13 of 13
(1,377 Views)
