Turn on off a strip led connected to MyRIO
Hi everyone!
I have a problem..I want to turn off and on a strip led RGB (like the one on the picture) connected to MyRIO.
I've already connected the 12v cable to +15v pin and the green cable to DIO0 pin and it turns green but I don't be able to turn it off.
(3,567 Views)
I believe the +15V line is always going to be on.
You can connect it to one of the DIO lines and control that using something like this ( https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DbJoSAK&l=en-US ) , but that will only be +5V, so probably not enough for your LED.
(3,554 Views)
Thanks for your answer!
The video is very clear but I should connect the strip led to MyRIO, not to MyDAQ so I have different commandsSmiley Sad
I can't find other useful tutorials..
(3,548 Views)
Oops, myRIO doesn't support DAQmx. Sorry about that.
Here is a tutorial on using the myRIO toolkit. Seems like the myRIO software comes with some Express VIs to control Digital Output:
https://www.ni.com/en/support/documentation/supplemental/13/required-and-optional-software-to-progra...
(3,537 Views)
