Two 1D Waveforms
I am using DAQmx Read (Analog 1D wfm NChan NSamp).vi twice, once to read Dev/ai0 and Dev/Ai1, two analog inputs from a PXI-6052.  I can make a waveform chart plot either one or the other, but I want them both to appear on the same waveform chart.  How do I do this?
Kevin
(4,749 Views)
Accepted by atomless
Use an array. Check the example that ships with LabVIEW.
(4,743 Views)
But why would you be using two separate DAQmx Reads?
(4,734 Views)
Hi Dennis:  How do you use a single DAQmx Read for more than one input?
Kevin
(4,661 Views)
Just by specifying multiple channels. For example, Dev1/ai0:ai1. You can choose multiple channels by clicking on the physical channel control and selecting browse.
(4,657 Views)
Like this:
Peter Flores
Applications Engineer
(4,610 Views)
