Two Discrete Kalman filters in one While Loop
Hi!
Is there any way to use two Kalman filters in one While Loop? When I use just one, no matter which one, everything works.
Thanks in advance!!
(2,744 Views)
Depends how you're trying to use them.  Care to share some code so we can understand your problem?
GCentral
(2,737 Views)
There are two separate Kalman filters, they don't depend on each other. There is nothing special in the code and I don't have it right now, just two Kalman filters which refuse to work at the same time.
(2,733 Views)
If the Kalman filters are using the same VIs, try setting the subVIs to Reentrant (VI Properties in the Execution tab).  By default, reentrancy is turned off for a new VI and therefore a single copy of every VI uses the same memory space and can only be ran by one thread at a time.
GCentral
(2,718 Views)
