Two port serial reading of a numerical value
Hi Danil,
you have a potential race condition due to uncoordinated read/write access to one ressource...
Message 11 of 32
(1,762 Views)
How can we avoid such  race condition??Is there any other way to give continuous numerical input in this case?
Thanks as kudos only:)
Message 12 of 32
(1,757 Views)
Hi GerdW,
               I somewhat solved the issue by giving a constant value(1) in bytecount of VISA read.But that time we can read only single digit.While giving value 2 to bytecount it works but while stoping the VI it is showing time out error.Please make some comments to solve this issue.
Message 13 of 32
(1,746 Views)
Accepted by danil33
You can check for the bytes available at the port and then you can read the data. Check the attached vi. This will not give you the timeout error as it only executes whenever you recieve any data at your port.
Message 14 of 32
(1,742 Views)
Hi Anand,
              Thank you so much.I also solved the issue by doing so in the attached vi.But I think mine is not the correct way.Anyway thankyou.
Message 15 of 32
(1,737 Views)
     suppose we have another indicator,Can we display another set of values in that indicator?
Message 16 of 32
(1,743 Views)
Hi Danil,
"Can we display another set of values in that indicator?"
Definitely YES!
Message 17 of 32
(1,741 Views)
So,how can we give input to the second indicator?
Message 18 of 32
(1,739 Views)
Just wire it. 🙂
Message 19 of 32
(1,736 Views)
Yes,both of the indicators display the same values.But Iam asking can we display different values( that is while indicator1 showing 34 at that time indicator2 showing 45)
Message 20 of 32
(1,734 Views)
