Two problems of histogram
This is my histogram
Q1 : x-axis the number 0 and the number 7 width is the half of others , how to change same width?
Q2 : x-axis from 0 to 7 , I want to change the 1 to 8, but I direct change in the pattern , it will become following picture
The entire graphics will shift , How can I solve?
THANKS~!
(3,909 Views)
First and foremost, a bar chart is not the same as a histogram... so that maybe the source of your first problem.
Regarding question to, have you tried changing the histograms xscale range min/max properties?
(3,904 Views)
Hi 多多
A1: You cannot currently change the width of the bar at the edges of a chart to be the same as the ones inside of it.
I'm not sure that I understand your second question.
Kind Regards
Chris | Applications Engineer NIUK
(3,899 Views)
HI,all
I have been change my title(bar chart -> histogram)
and I have been solve my second problem , choose properties->scales->Offesets
But I still can't solve my first width problem
TO hicksc : Do you mean that I can't solve this problem now?
(3,891 Views)
Yes, I'm sorry - we currently have this in our CAR(Corrective Action Request) database but it has not yet been actioned.
Kind Regards
(3,887 Views)
OK, thank you for your help~
(3,883 Views)
