Two progress bar joined or two diferent scale range in one progess bar!
Hello guys,
I try to get 2 diferent scales range in one progess bar. But I cant get it.
So, I tried to join 2 progess bar putting the fit scales to look similar like I want to. One from 0 to 100 and the second from 100 to 300.
In case I need to use 2 progress bar, the problem is the second start with mark in the start, I would like the second to be totally clear from 0.
Is it possible?.
Regards.
(3,169 Views)
Dear Fonsi,
When progress bar is equal to 0, it will display a thin color at 0 point.
So I use property node to change fill color.
Patrick
Certified LabVIEW Developer
(3,149 Views)
THanks for reply!.
Can you update to lv2013?.
Regards.
(3,138 Views)
Accepted by topic author Fonsi
Alternatively, you could set the Fill Style.  0 is no fill while 1 is Fill To Min.
GCentral
(3,131 Views)
Thank you crossrulz!.
It is valid for me.
(3,106 Views)
