Type Def wont allow edit
I cant seem to update y type def even though i have edited it many times before. All i want to do is add another box in there but for some reason i cant. please help and keep in mind i am new to Labview. Thank you
Message 1 of 8
(3,429 Views)
A picture does not help solve the problem. Can you attach the typedef instead?
Message 2 of 8
(3,414 Views)
i actually solved the problem thanks for the reply anyway
Message 3 of 8
(3,395 Views)
If you tell us how you solved it, people will be thankful to you.
Message 4 of 8
(3,390 Views)
Some wild guesses:
  • Trying to edit the front panel instance instead of the typedef
  • typedef is reserved in an already running other VI
  • etc.
Message 5 of 8
(3,360 Views)
  • trying to edit a cluster type def that's inside a cluster type def
the picture looks like what I saw as I tried that yesterday and is hard to see.
Message 6 of 8
(3,333 Views)
Accepted by MBSHIRAZIZ
So the inner typdef was strict, and that's why you couldn't edit it.  You had to open the inner typedef before you could edit it.
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(3,316 Views)
I really wish I had the X-ray vision of all of you to tell all that from a truncated picture. 😮
(I couldn't even tell of it shows the control editor or a front panel instance :D)
Message 8 of 8
(3,288 Views)
