Type not supported in current target.
Hi I am trying to write a simple FPGA program to read in an array and output it one number at a time. But i get errors saying Type not supported in Current Target. What am i doing wrong. my code is belowfpga.png
Message 1 of 18
(10,198 Views)
Accepted by zepp2
FPGA does not supporting floating point numbers (like DBL). You'll have to use integers or fixed point numbers.
You're converting the DBL to I16 anyway, so make the array I16.
Message 2 of 18
(10,196 Views)
Thanks works prefectly
Message 3 of 18
(10,190 Views)
Just a quick update to this old thread. LabVIEW 2012 added support for single precision floating point; if that precision is sufficient for your application it may be a better/faster option than converting to fixed point.
Message 4 of 18
(9,984 Views)
Could you please help me with my VI, I am trying to do a loop but the FPGA gives me the error!
Message 5 of 18
(9,135 Views)
Double Precision Floating Point (DBL) numbers are not allowed in the FPGA.  For your Divide By 2 inside of the loop, I recommend using a Logical Shift with a y value of -1 (shift to the right 1 bit, which is a very cheap way to do a divide by 2 of an integer in FPGA).
For the Divide going into AO0, I recommend using Quotient & Remainder instead.
Message 6 of 18
(9,123 Views)
My friend, I changed based on your guides but it is not working can you plesae see the VI
Message 7 of 18
(9,106 Views)
Define "it is not working".  The VI won't compile?  Your outputs are wrong?
Message 8 of 18
(9,099 Views)
I can not compile since it is saying "Type not supported in current target." the problem is that the loop is generating DBL numbers, I think so!!!
Message 9 of 18
(9,092 Views)
The last update does not have any DBL.  When I put the VI into an FPGA project, it works just fine.
Message 10 of 18
(9,086 Views)
