Type of wires and feedback node
I need to run the following code in LabView FPGA, hence I need to use FXP.
Everything works fine and stays at FXP until I insert the feedback node. Then the data type flips to double and it can not run on the FPGA any more:feedback node and types.PNG
How can I force all the internal wires to be FXP?
Thanks a lot,
Michael
Message 1 of 10
(5,724 Views)
It would be much easier to help debugging a VI instead of a picture.
Are all of the FXP controls, indicators, and constants set to the same configuration?
Message 2 of 10
(5,716 Views)
It might have to do with the order that wires were connected to the feedback node.
Try disconnecting the wire that goes from the output of the Subract to the right side of the feedback node;
then reconnect it.
Message 3 of 10
(5,698 Views)
I tried this. And it all Looks good, until I "Close the Loop" via the Feedback node. Then it swiches to double.
Message 4 of 10
(5,695 Views)
Good Point and thanks for considering...
I dont know how to edit the original post, so I append here as a reply.
Message 5 of 10
(5,694 Views)
I was able to get it to play nice by adding a to fixed point after the feedback node ¯\_(ツ)_/¯
Can you do that in FPGA land?
Message 6 of 10
(5,672 Views)
No it is still not working, because the wire section between the Feedback node and the "to fixed-Point" is displayed as double, which is not allowed in FPGA land...
Message 7 of 10
(5,665 Views)
Accepted by topic author Michael2018
Did you wire the fixed point type?
Message 8 of 10
(5,660 Views)
Awesome, I think I tried every Permutation, but failed to add the constant to the fxp converter.
Thanks!
Message 9 of 10
(5,658 Views)
Especially with FXP, it is not advisable to have all these diagram constant floating around, it makes things much harder to maintain, e.g. if you would change FXP type. (Herding cats comes to mind :D)
I would just source all the types from the same place instead. (... And if the FN should be initialized with zero, just change accordingly).
(And yes, type propagation sometimes fails, so there is probably a small bug somewhere)
Message 10 of 10
(5,641 Views)
