TypeDef to Tree
Accepted by Dealcs2
Here is an attempt without recursion and a faster insert method. Items must be sorted for this to work properly.
Message 11 of 16
(2,374 Views)
@Dealcs2 wrote:
Thanks for the help on this! Is there anyway that you can save in for LV2019? It looks like you are on 2020 and I am still on 2019 😞
Sure.
Message 12 of 16
(2,366 Views)
This works great! Thanks for the help on this! The only this is that I cannot have something like A.6 and then A.6.a. But really that is perfectly fine for the application. Thanks again!
Message 13 of 16
(2,345 Views)
This seems to only be populating a few elements. Am I using it wrong?
Message 14 of 16
(2,343 Views)
Yes.
You have to use the VI as a sub VI. So putting a tree on the front panel of the sub VI is wrong. Put a tree control on a new VI, then call the sub VI. See how to use.
Message 15 of 16
(2,321 Views)
Got it! Did not catch that the VI was a clone. This works great. Thanks!
Message 16 of 16
(2,306 Views)
