UDL to mysql 5.7
Hi Sir,
I install the mysql in local PC, and try to create the UDL for connection, but always failed.
I am not sure the setting is correct, kindly give some comments.
This maybe is not labview related, but appreciate very much if you can give some comments.
Thanks.
Keep moving
(5,444 Views)
Or in another word, what kind of provider should i choose for mysql ?
For this case, i use Microsoft OLE DB provider for SQL server.
Thanks.
Keep moving
(5,378 Views)
Hola, debes usar Microsoft OLE DB Provider  for OBDC Drivers.
(5,257 Views)
First of all, you need the ODBC driver for your database and for the bitness of your LabVIEW installed. That is, for a 32Bit LabVIEW, you need the 32Bit driver, regardless of the bitness of the database.
And for the rest, always make sure to use tools for the correct bitness.
Create a ODBC connection by pressing [WINDOWS] and typing ODBC. Windows will suggest ODBC Datasources 32Bit and 64Bit.  Choose the same bitness as your LabVIEW.
Add a new datasource with your driver either as User-, System- or File-DSN
You will be asked for the connection details and can configure further settings.
Once this is done, you can (but do not want to) create a UDL-file which links to the ODBC connection "MyDSN". Remember, for 32Bit on 64Bit system, you need the correct 32Bit-tool. Use this command to open an existing (even empty) UDL file as 32Bit:
C:\Windows\syswow64\rundll32.exe "C:\Program Files (x86)\Common Files\System\Ole DB\oledb32.dll", OpenDSLFile C:\x.udl
Choose "Microsoft OLE DB Provider for ODBC Drivers" on the provider tab. On the connection tab, "MyDSN" should be available as data source.
However:
LabVIEW can directly connect to a ODBC connection. Just wire a string "MyDSN" instead of a path to the database open VI. There is no need for an UDL file.
Further more, LabVIEW can use a DSN file instead of a UDL file, too.
I always had some trouble to create a File-DSN with the tools shown above. But it is just a text file (like UDL), and looks like this:
[ODBC]
DRIVER=MariaDB ODBC 3.0 Driver
Server=ServerIpAddress
User=Me
Password=password123
DATABASE=myDatabase
AUTO_RECONNECT=1
By the way: You also just wire the content of an UDL file to the open VI, this does not work for DSN.
(5,247 Views)
hello,
You mean just choose that for mysql, no need to install extra drivers ?
Thanks.
Keep moving
(5,233 Views)
Thanks.
Later i install the odbc driver, then it works.
Keep moving
(5,230 Views)
