XML format issue
Hi team ,
I am writing the array data  content as xml file .
In the XML file , test parameters name also ( Caption )   i need to Write  .
I gave as 1d array as output  , so all caption / Parameters are all listed as " Status " .
But  parameter name  i need to write first ,  after that  i need to write the parameter value in the file
For eg :
Parameter name  : Testcase name
Parameter value  : Voltage Test
Parameter Name : Higher limit Value
Parameter  value  :  5
Attached the screenshot of xml file and Test vi .
Please advise and suggest
Thanks in advance
(2,572 Views)
use a cluster instead of an array, because in an array, every element has the same name
is this related to this post?
https://forums.ni.com/t5/LabVIEW/Format-XML-data/td-p/4075392
(2,516 Views)
(2,477 Views)
Hi team ,
After a googling and workout i used a parser method and content was written .
Please find attachment and refer image
But i need to change a format  little bit .
Testcase details need to printed in 1 line ( Horizontal manner  )
Next testcase details ( name , offset , parameters ) to be printed in the next line .
In existing format i attached , every parameter are printed in a every new line
Thanks in advance !
Please advise
(2,410 Views)
